ASPECT RATIO problems with DVD Studio Pro 3
COW Forums : DVD Authoring
carly_abyss
on Jun 7, 2005 at 12:46:30 pm
So... I have a 16x9 project that I have created in DVD Studio Pro 3. But for some reason when I put the disc in some DVD players, it centre cuts the menus. And then when you click on a button, the feature movie letterboxes. Why aren't the menus recognised as 16x9 and also letterboxed when played on a 4x3 television?
What am I not getting here?
HELP !
Borjis
Re: ASPECT RATIO problems with DVD Studio Pro 3
on Jun 7, 2005 at 8:07:55 pm
what do you mean by "centre cuts the menu?"
Did you design the menu's with a 16x9 ratio
before resizing them to 720x480 for authoring?
Are there multiple video title sets in your project?
This allows 4:3 and 16:9 on the same disc.
Kieran Matthew
on Jun 12, 2005 at 12:20:14 am
There's a check box in the general settings pane of the disc that says something like "if 16:9 is used...". By default in DSP3 this is set to "Force to Pan & Scan" which zooms the centre section of your 16:9 menu. Set it to "force to letterbox" and it should solve the menu issue.
