dvd studio pro -encoding settings
COW Forums : DVD Authoring
Matt Goldschmidt
on Jun 6, 2005 at 10:27:25 pm
what is the BEST encode settings?
Video standard - NTSC (of course)
Aspect ratio - 4:3 (of course)
Field order - ?????
Encode Mode - ????
Bit Rate - ???
Max Bit Rate - ???
Motion Estimations- ???
Help - If had some hang ups and freezing.
Im using quicktime (same as source) direct out of Final Cut Pro HD
Re: dvd studio pro -encoding settings
on Jun 7, 2005 at 12:59:30 am
[Matt Goldschmidt] "what is the BEST encode settings?"
I'm mot trying to be cagey, but the best encoding settings vary from project to project.
[Matt Goldschmidt] "Field order - ?????"
Depends on your source material. DV is lower field 1st.
[Matt Goldschmidt] "Bit Rate - ???"
Depends on how much material (total # of minutes, including extras) is going on how big a disk.
[Matt Goldschmidt] "Max Bit Rate - ???"
No higher than 7 for disks being burned on a desktop. That assumes that you're compressing your audio with aPack.
© 2018 All Rights Reserved
