DVD skip,hang, What should I do?
COW Forums : DVD Authoring
Matt Goldschmidt
on Jun 6, 2005 at 6:26:42 pm
My final product skips and hangs. What is the best DVD to burn to? sony,memorex, etc.
Its gota be a - , and I am using DVDStudioPro 2.
Is there a sensitivity setting for the burn stage?
Im on a mac 0sx - should I close all programs during burn? Could that be causing a colflict?
Finally, I dont thik this has anything to do with it, but I used FinalCutHD to export (quicktimes)
HELP
thanks
Ed
Re: DVD skip,hang, What should I do?
by
on Jun 6, 2005 at 8:33:09 pm
Are you creating an MPEG2 before burning? And at what bit rate?
Ed
Borjis
on Jun 6, 2005 at 9:15:27 pm
Your bitrate should not exceed 7,000
Your audio should be Dolby AC-3 around 256kbps or better.
Quality Media like Verbatim & Ritek/Ridata will help as well.
Matt Goldschmidt
on Jun 6, 2005 at 9:17:18 pm
so.... how do I set these in DVDStudio Pro 2? I have been using the defult bun
Borjis
on Jun 6, 2005 at 9:23:20 pm
It's during the compression step.
How are you compressing your video?
With apple compressor or quicktime perhaps?
also, you should be burning the disc at 1x just
for extra precaution.
Matt Goldschmidt
on Jun 6, 2005 at 9:31:46 pm
I guess Im just using the defult. How do I get to the compression settings.
