DVDSP- can't make subtitle menu button work
COW Forums : DVD Authoring
John Dobovan
on Jun 4, 2005 at 5:20:33 pm
I would sure appreciate somebody's help with this one. I have a finished program with subtitles that are supposed to be activated through a menu but I can't figure out how to make the menu button turn on the subtitles. I've set the correct subtitle stream in the inspector window for that button and then set program play as the target for that button. But when I test this it doesn't activate the subtitles - the program starts to play without subtitles. The only way I can activate subtitles at present is by using the subtitle button on the remote control of my DVD player. Any suggestions on how to make this button work?
TIA,
JD
