Compressor and Format. This is probably an easy one!
COW Forums : DVD Authoring
Cameron
on Jun 1, 2005 at 4:07:05 pm
When creating quicktime movies that will be used on a DVD what type of compressor should I specify?
These are a few of them that are listed:
Animation
Cinepak
DV-PAL
DV/DVCPRO-NTSC
DVCPRO-PAL
Mpeg-4
Sorenson 3 video
and about 10 more...
Also what is the best format?
the options are:
16 bit color
24 bit color
32 bit color
etc.
Thanks!!!!
cameron
Borjis
Re: Compressor and Format. This is probably an easy one!
on Jun 1, 2005 at 4:24:30 pm
none of those will work. You need the one that says mpeg2.
Cameron
on Jun 1, 2005 at 6:27:48 pm
Can export my movie in After Effects to mpeg2?
thanks!
Borjis
on Jun 1, 2005 at 8:22:38 pm
if you have 6.5 on the pc yes, I think you can.
I don't think the mac version supports mpeg2 output yet.
You could export it as an ANIMATION file then compress
that with an mpeg encoder software.
Thats How I do all of my dvd menu's.
If you have apple compressor, it should have an mpeg2
output module.
