Maestro Sync Problem
COW Forums : DVD Authoring
Rebecca Davis
on May 26, 2005 at 11:20:48 am
I am experiencing sync problems of about 6 frames in the audio stream. The sync is not gradually getting worse, rather it stays a consistent 6 frames ahead or behind. I noticed in my asset bin that the duration of the mpeg and ac3 streams are not the same. Furthermore, I've noticed that when using non-drop frame masters, the durations between the encoded files are the same. Has anyone else experienced this problem? Has anyone got a fix for this?
The specifics of my current project are:
BSP Drop Frame Masters
Sony DVWA510 DigiBeta Player
Spruce MPX 3000
Any insight would really be appreciated.
Re: Maestro Sync Problem
on May 26, 2005 at 1:15:29 pm
If the audio stream is not the same duration within a few
frames, thats the problem first and foremost.
Does it happen on a short clip?
I would encode for 1 to 5 minutes and test that first.
Probably not Maestro causing it.
Try capturing the drop-frame masters as non-drop.
Doesn't make sense but it could fix it.
Let us know the solution when you find it.
Bill Stephan
on May 26, 2005 at 4:08:45 pm
Drop frame time codes do somtimes cause problems in certain authoring apps. I agree with Borjis that you should try encoding non-drop frame.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
© 2018 All Rights Reserved
