DVD Duplicators
COW Forums : DVD Authoring
Marty Lucas
DVD Duplicators
on May 18, 2005 at 6:52:40 pm
Greetings everyone!
Just wanted to know if any of you could reccomend a good DVD stand-alone duplicator? The only requirement is that the actual units should be Dual-Layer...
Thanks in advance!
Jason Casey
Re: DVD Duplicators
on May 18, 2005 at 8:00:58 pm
I've always reccomended that you build your own...VERY easy to do and will save you a TON of $$$!!
Controller cards here
Case here
Drives here
Of course you can always replace the drives with whatever model you prefer. I just build six 1-7 Duplicators using these parts a while ago and everything has been wkring fine...just install the latest firlware for the Pioneer drives if you do go with them.
© 2018 All Rights Reserved
