4 gig limit on XP pro
COW Forums : DVD Authoring
Brian Mills
on May 9, 2005 at 5:00:00 pm
Im getting an error while trying to burn some mpeg2s that are over 4 gigs onto a dvd for data storage...Im using Pioneer RecordNow DX...is this an OS problem or software...and are there any work arounds?
Roadkill
Re: 4 gig limit on XP pro
on May 9, 2005 at 11:40:28 pm
Brian,
Can't point you to the setting in RecordNow, but you could try changing the file system from ISO to UDF or ISO/UDF.
Btw: A single layer DVD can't hold much more than 4GB. The Giga in "4.7GB" is decimal based (1,000,000,000 bytes), whereas the Gigabyte on a computer is binary based (1,073,741,824 bytes). This makes that a 4.7GB DVD has a storage capacity of about 4.37GB.
To avoid possible problems later, I would suggest to limit the size of a single file on a DVD to 4GB or less.
