24fps question
COW Forums : DVD Authoring
BabaG
24fps question
on Apr 27, 2005 at 8:32:24 pm
is there a true 24fps delivery medium for digital projection?
or is 24fps material always folded into a 30fps file and flagged
for pulldown removal?
thanks,
BabaG
Noah Kadner
Re: 24fps question
on Apr 28, 2005 at 3:36:36 pm
If you've watched nearly any Hollywood produced DVD of the past few years you've likely seen a native 24p DVD. The DVD player is adding in the pulldown when you watch on a 29.97 TV and progressive scan DVD players can output 24p native to plasma monitors and projectors.
Noah
BabaG
Re: 24fps question
on Apr 28, 2005 at 7:06:02 pm
thanks noah. what wiould be the file choice for projection?
would this be mpeg-2 as in dvd? or would one use a less
compressed format at a 24fps rate for projection?
thanks,
BabaG
Noah Kadner
Re: 24fps question
on Apr 28, 2005 at 9:37:50 pm
The simplest way is MPEG2 onto a DVD. There's many other ways to project- like QuickTime to MPEG4 or WMP if that's your thing. Worth some google time if you're interested in higher than DVD quality.
BabaG
Re: 24fps question
on Apr 29, 2005 at 6:27:44 pm
thanks noah. can you give a pointer or tip as to where to
start; search criteria maybe? what i've done so far just
leads me to things that are either unspecific or more
compressed/lower quality than mpeg-2 (like mpeg-4).
thanks again,
BabaG
Jonas Bendsen
Re: 24fps question
on Oct 28, 2009 at 11:48:48 pm
This is an ancient thread, but it came up when I was searching for an answer to my output questions.
I'm editing RED footage. It's 23.976. I assumed since DVD's are for NTSC televisions, I should be exporting my media to 29.97, but now I'm wondering.
Should I be using Adobe Premiere Pro CS4's MPEG-2 DVD 23.976p setting (vs. the "regular" setting which is 29.97) to author DVD's?
This is my life, I edit and edit and edit and edit...
Michael Sacci
Re: 24fps question
on Oct 29, 2009 at 3:24:04 am
If you are editing 24p footage on a 24p timeline you should encode the m2v as 24p, there is NO reason to make it 29.97. DVDs and DVD players automatically add the pulldown if the player is hooked up to a system that does not support 24p
24p=23.976p
Jonas Bendsen
Re: 24fps question
on Oct 29, 2009 at 4:47:39 am
Good to hear. I was assuming (and hoping) this was the answer, but I didn't want to be encoding all our DVD's as 24p (23.976), only to have DVD players not playing them correctly on NTSC TV's needing 29.97 for whatever reason.
Jonas Bendsen
Re: 24fps question
on Oct 30, 2009 at 8:52:35 am
I'm pretty sure you're wrong (this after spending hours encoding to 23.976 and compiling a DVD, setting poster frames, etc., only to find that the project won't build, because Encore is telling me there are "gaps" in the timeline).
Here is a link from the Adobe site:
http://help.adobe.com/en_US/EncoreDVD/4.0/WSbaf9cd7d26a2eabfe807401038582db...
The chart shows that Blu-Ray will function at 23.976, but an NTSC DVD will ONLY work with 29.97.
3am. Starting over exporting everything to a 29.97 file.
Michael Sacci
Re: 24fps question
on Oct 30, 2009 at 4:15:52 pm
well I have been authoring since 1999 and been encoding 24p from that time. When you encode m2v properly at 24p it puts flags in for the pull down so the player know to stream it as 29.97 if it is hooked up to a TV that does not handle true 24p. But every hollywood movie is done this way, the pull-down is added by the player not in encoding or source video.
Jonas Bendsen
Re: 24fps question
on Oct 30, 2009 at 4:26:24 pm
Just saying... I encoded to DVD MPEG-2 23.976 using Adobe's Media Encoder. When I pulled it into Encore, it wouldn't build, I'm assuming because of the framerate.
In Encore, the setting for fps in the Project Settings Window is 29.97 and there is no way to change it (it's grayed out, and Adobe's sight shows that a DVD can only be written at 29.97).
So for future readers using Encore CS4 to author DVD's... 23.976 seems to be the wrong way to go.
I could be wrong, but this is what I learned from my experience.
Jonas Bendsen
Re: 24fps question
on Oct 30, 2009 at 4:28:59 pm
ps I'm not saying there's no way to do it. I'd love to know the method (or work around) for authoring 24p (23.976) DVD's with the Adobe Suite if anybody knows how to make it happen.
patrick gonzales
Re: 24fps question
on Sep 20, 2010 at 1:05:54 am
I know exactly what you mean Encore doesn't offer producing Standard DVD at 24pfs just 29.97pfs. What's up with that. However, it does allow you to produce a Bluray DVD in 24pfs and works out fine.
One problem I think you are going to have with your footage is that if you capture it in 24pfs it still doesn't come out right just because you edited in a 29.97 sequence and export that way. Encore just needs to offer that option. I am not sure if it is offer in CS5, but it doesn't for CS4.
Any Solutions?
Using Adobe Premiere and Encore CS4.
captured 24pfs
Jan Van Roey
Re: 24fps question
on Jun 30, 2011 at 1:54:07 am
Hello Michael,
How can I create a high quality DVD (PAL and/or NTSC) from an mpeg4 24fps file please?
Thanks.
Jan
