Needing some extreme slow-mo
COW Forums : Cinematography
Todd Terry
on May 18, 2015 at 9:31:20 pm
Hi all...
I've never had to do any real extreme slow-mo before (nothing faster than my own in-house cameras could handle), but now I'm tasked with such.
For an upcoming project I need some much-more-overcranked shots than I'm used to (or equipped for) getting (probably something in the 1,000-1,200fps range, just a guess).
My first thoughts are just to rent a Phantom for the shoot (probably the Miro). At first blush that seems to be the easiest/best/fastest/cheapest way to do it... but, having never had this need before, I could be wrong.
I'm perfectly happy to do it that way, but wanted to see if anyone had a "Have you thought about such-and-such..." that would be better.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Rick Amundson
Re: Needing some extreme slow-mo
on May 18, 2015 at 9:38:25 pm
Todd,
You are on the right track. I've used the Miro a few times and it is the easiest way to get the speeds you are talking about.
Best of luck!
Rick Amundson
Producer/Director/DP
Screenscape Studios
Bravo Romeo Entertainment
http://www.screenscapestudios.com
http://www.bravoromeo.com
http://www.indeliblemovie.com
Gary Huff
on May 18, 2015 at 10:03:26 pm
To ditto Rick, if you need that slow, Phantom is basically your only option.
Todd Terry
on May 18, 2015 at 10:20:05 pm
Thanks Rick and Gary...
Haven't used it, but you can rent a Miro pretty cheaply, about $1500 a day (or a little more than $2K for a week), seems pretty straightforward and don't need a Phantom tech, and it will go more than fast enough for what I need.
I appreciate the backup....
T2
Todd Terry
Creative Director
Blaise Douros
on May 19, 2015 at 5:05:17 pm
Don't forget to budget for some extra lighting--depending on how fast you're going, you may need a little extra punch at those speeds!
Todd Terry
on May 19, 2015 at 5:37:57 pm
Yeah I figired I would need plenty of light.
Even though we use much lower light levels these days than in years' past (I pretty much exclusively light with battery LEDs now), I still uaually keep a couple of HMIs on the truck, just in case. Hopefully that will cover us.
Thanks to all for the advice.
T2
Todd Terry
Creative Director
