What is this blue "halo" on my foootage?
COW Forums : Cinematography
Fred Roberts
on May 29, 2014 at 6:56:51 pm
Hello- I've seen this before on low quality cameras, but does anyone know what causes this blue "halo" around white objects in this frame and how to resolve it (in camera)?
Thank you.
Mark Suszko
Re: What is this blue "halo" on my foootage?
on May 29, 2014 at 8:04:47 pm
Halation? I think it's fringing from the high contrast between the hard bright white and the black BG.
Fred Roberts
on May 29, 2014 at 8:40:34 pm
That's a good thought. Thank you. The guy is using a new camera...previous camera didn't have this problem with the same set up (contrast).
Emre Tufekcioglu
on Jun 9, 2014 at 4:55:53 pm
That is called chromatic aberration, it is a physical limitation of a lens. Higher end cameras that employ more expensive lenses and chromatic aberration correction software will have less of it.
You will get CA when:
-You are using a long lens (zooming in a lot)
-High contrast
-low cost gear
http://en.wikipedia.org/wiki/Chromatic_aberration
http://photographylife.com/what-is-chromatic-aberration
Fred Roberts
on Jun 9, 2014 at 8:42:04 pm
Thanks Emre. I guess I just didn't believe that was still possible with cameras today! Appreciate your response.
