Mount a C300 90 degrees
COW Forums : Cinematography
Rich Rubasch
on Aug 23, 2013 at 2:35:18 pm
Hi all; Shooting some fashion shots on green screen and the talent will not move around much. To get the most resolution we want to mount the camera sideways and shoot in a vertical frame.
Thoughts? We have a Miller tripod and a 75mm head.
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Angelo Lorenzo
Re: Mount a C300 90 degrees
on Aug 26, 2013 at 11:26:08 pm
I'd just go with a hardware store L bracket with a center slot cut to fit a 3/8" bolt, some 3/8" washers, bolts and wingnuts, maybe some nylon washers to avoid slippage. Photographic ball heads usually have a sturdy vertical position that would offer an alternative if you could find or retrofit one with a 3/8 bolt
If you need to operate pan/tilt, you'd be better off sourcing a Lambda head and Mitchell plate tripod.
Just the first thoughts that come to mind.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
© 2018 All Rights Reserved
