Dimming a softbox
COW Forums : Cinematography
Dylan Hargreaves
Dimming a softbox
on Dec 29, 2012 at 12:26:05 pm
Hey folks,
I have a Photoflex Starlite softbox which is proving next to useless for 99% of the time I need it due it simply being too powerful.
What solutions are there to dim one of these softboxes without causing the colour temperature to drop?
Thanks in advance!
D
Rick Wise
Re: Dimming a softbox
on Dec 29, 2012 at 7:35:29 pm
I'm not sure what kind of lamp housing you are using with your soft box. Solutions: lamp with smaller (less wattage) lamp(s); add wire scrims in front of the bulb housing if possible; add ND sheets to the front of the unit.
Rick Wise
Cinematographer
San Francisco Bay Area
http://www.RickWiseDP.com
Todd Terry
on Dec 29, 2012 at 7:53:04 pm
All of Rick's suggestions are good ones.
The easiest would be to use a different lamp. I wouldn't use the "real" Starlite globe. If I recall they are 500w or 1000w clear glass bare bulbs. I believe they have a regular Edison screw-in base so it would be super easy to put a lower-wattage tungsten or CFL lamp in it.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Dylan Hargreaves
on Dec 30, 2012 at 2:02:45 pm
Thanks both!
Mark Suszko
on Dec 31, 2012 at 8:55:03 pm
And if you don't have any of those, there's always the square-cubed law.... though, the farther back you pull it, the more chances you need extra flagging to hold back any spill.
