PANASONIC AF100 Match SONY HVR-Z5 Image settings Picture Profile
COW Forums : Cinematography
gabriele fuso
on Jan 17, 2012 at 12:17:28 am
Hello,
I ask you an advice about the image profile to use for an event that will be shot with Panasonic AF-100 (currently using the Range Scene file by Andy Shipsides of Abelcine) and Sony HVR-Z5 (never used).
Has anyone ever worked with these two cameras on the same project?
gab
Alan Lloyd
Re: PANASONIC AF100 Match SONY HVR-Z5 Image settings Picture Profile
on Jan 21, 2012 at 8:36:41 pm
I suspect the best you can hope for is to tweak each of them using the same monitor and subject matter beforehand, then once you've got them as close as possible, do the rest in post.
gabriele fuso
on Jan 22, 2012 at 3:32:17 am
Thank you Alan,
I solved by using Picture Profile Cinelook1 on Sony Z5, and the Scene File 4 (by Andy Shipsides of Abelcine) with AF-100.
Slight adjustment of midtones in post.
