HDSDI monitor for 7D 5D
COW Forums : Cinematography
Tim Sorel
on Jan 24, 2011 at 10:11:42 pm
Hello
I am getting ready to shoot a short feature with the 7D. I have a great deal of HD gear including 17" and 9" Panasonic HDSDI monitors. I am going to try to use an AJA HDMI to HDSDI converter to feed a monitor for the director and camera operator.
http://www.bhphotovideo.com/c/product/555772-REG/AJA_HA5_HA5_HDMI_to_SD_HD_...
Has anyone tried this or know of why this may not work? I understand the cameras go into SD when recording. Other than that I do not have that much experience with this type of set up.
Tim Sorel
Gainesville, FL
Richard Cooper
Re: HDSDI monitor for 7D 5D
on Feb 1, 2011 at 7:12:38 pm
Hi Tim,
This should fit your needs nicely. Keep in mind it needs a power supply but you probably noticed that. Nice thing is that it actually has 2 HD/SDI outs so you can simultaneously go out to 2 monitors. Very handy.
Also... while the other cannons down-convert upon recording you will find the 7D does not. While it is not a "clean" 1080p signal it is a nice hi res version (Not sure the exact specs) that looks great on an external monitor.
Good Luck!
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
Bob Cole
on Feb 3, 2011 at 4:22:45 pm
[Richard Cooper] "while the other cannons down-convert upon recording you will find the 7D does not."
Do all the other Canon DSLRs down-convert the external video signal on recording? What about the 60d?
