how to soften hd video
COW Forums : Cinematography
noor hussain
on Oct 28, 2010 at 5:39:29 pm
i have a canon 7d.i need to know how can i soften the overall video.hd is a bit crisp n too sharp
Mark Suszko
Re: how to soften hd video
on Oct 28, 2010 at 7:06:31 pm
In-camera, or in post?
noor hussain
on Oct 29, 2010 at 10:37:27 am
IT WOULD BE GREAT if you can breakdown different procedures.You know how the result of film is a little softer than video.
some say you have to decrease the contour correction .some in built feature of video cameras to sharpen the image.hd video is quite hard in a way.
Richard Cooper
on Oct 29, 2010 at 8:42:44 pm
On the 7D, try dialing down your "sharpness" setting all the way to the left, same with your "contrast". Then dial down your "saturation" by 2 clicks from center. This will give you a nice color gradable image and will reduce that "sharp look" you are referring to.
Hope this helps.
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
noor hussain
on Oct 30, 2010 at 4:31:05 am
thankyou so much sir
Should i use soft focus as well or not?
Richard Cooper
on Oct 31, 2010 at 11:44:09 pm
"Should i use soft focus as well or not?"
Not unless you need it for a specific look... and NEVER do this in camera.... Unless you are absolutely SURE you want it that way... save it for post if you really want that specific look.
Richard Cooper
Anchorage, Alaska
noor hussain
on Nov 1, 2010 at 3:06:59 pm
got it !!!! thanks sir
