Image Stabilization
COW Forums : Cinematography
Varun Chandramohan
Image Stabilization
on Jul 14, 2010 at 4:14:21 pm
Folks, Iam totally confused! I narrowed down on 3 cameras and wanted to buy one of them. Iam not able to decide which is the right choice for me. If you guys can answer the set of questions i have it will be great.
The camcoders i chose are
- Canon VIXIA HF M31 (http://www.usa.canon.com/cusa/consumer/products/camcorders/consumer_camcorders/vixia_hf_m31#Specifications)
- Sony HDR-CX350V (http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921666073295#features)
- Panasonic HDC-HS250K (http://www2.panasonic.com/consumer-electronics/shop/Cameras-Camcorders/Camcorders/3-MOS-High-Def-Camcorders/model.HDC-HS250K.S_11002_7000000000000005702#tabsection)
1)I need optical image stabilization, HD and good zoom!
I see all models have the first 2. Optical zoom of 25x is present in Panasonic model against others. Also Panasonic says it provides 3 cmos sensors and i read that multiple cmos sensors have better quality! Is it true?
I see panasonic have lower Mega Pixel value compared to the other two but with higher zoom. Whats the concept? Does a little less pixel value matter? Or can zoom be compromised?
2)Only Canon model seem to have input audio jack for external mics. I always thought that its very important to have that to get better audio? Did i get it wrong? Can this feature be over looked?
3)Canon and Sony are flash based. Is it possible to add bigger flash cards when we run out of space? The Panasonic is HD based! Iam not sure if hard disk based systems are good idea. It also says we can have additional flash cards. Is that true in case of panasonic?
Can someone be patient enough to answer all these questions? Iam very desperate. I have to buy this in a week and not yet decided. Please help.
Micah McDowell
Re: Image Stabilization
on Jul 14, 2010 at 4:46:31 pm
1. Generally, the three sensors of the Panasonic would be an advantage, but from reviews and experience, I'd say the Canon will produce a better image. Forget the megapixel values of the sensors; full HD video is only 2MP, and those numbers are basically useless except for stills. The stills from these cameras will be lousy regardless. Megapixels have nothing to do with zoom.
2. If you want good audio, especially for interviews, you need an external mic. This is important.
3. The Sony and Canon have 32GB of internal flash memory while the Panny has 120GB of hard drive space. However, all three allow you to use SDHC cards for extra storage. I'm not a big fan of the hard drive cameras for reliability concerns.
Conclusion: all three cameras are very similar so don't stress out about the choice. I have a strong preference for the Canon since it has a mic jack and the VIXIAs generally have great image quality. None of the three are anything approaching a good quality pro camera, but they're great for the price.
Varun Chandramohan
on Jul 15, 2010 at 6:06:38 am
Thanks a lot guys! It helped a lot! I think i will go with canon VIXIA HF M300. I plan to buy http://www.buy.com/prod/kingston-32gb-flash-memory-sdhc-class-4-flash-card/... as the SDHC card. Will that be good enough? The canon site says, Panasonic, Sandisk as the recommended vendors for the SDHC card, but iam going with Kingston...will that be ok?
Terry Mikkelsen
on Jul 15, 2010 at 3:30:02 pm
Though I've never used a camera with flash chips - I would assume that you are fine. Just make sure you stick with the Class 4 or higher if you want to shoot HD.
Tech-T Productions
http://www.technical-t.com
Terry Mikkelsen
on Jul 14, 2010 at 5:50:25 pm
This response purposely only addresses one of the three cameras you list. I only looked at the Canon, since you said it has audio inputs and the other do not.
Most of the reviews of the HF M31 say that is really has nothing different from the previous models (HF20 & HF200). So obviously because they are not the current model they will be cheaper. The HF20 has 32GB internally and it doesn't look as though you can replace or add more. The HF200 comes with 0 memory, but you can get whatever you want and can expand more as you need.
So, from the information that you provided, I would choose the Canon HF200.
Tech-T Productions
Rick Wise
on Jul 14, 2010 at 7:14:54 pm
The Canon HF200 is no more, unless you can find it used. Replaced by the Canon HF300 (http://www.bhphotovideo.com/c/product/671648-REG/Canon_3536B001_VIXIA_HF200...). This camera is minuscule! Only a little over four inches long.... Relatively cheap -- $458 on sale at the moment. Appears to have some manual controls. Looks cool for quick and easy.
Rick Wise
director of photography
San Francisco Bay Area
and part-time instructor lighting and camera
grad school, SF Academy of Art University/Film and Video
http://www.RickWiseDP.com
http://www.linkedin.com/in/rwise
email: Rick@RickWiseDP.com
