HMI Flicker in Pal Land
COW Forums : Cinematography
Bob Pierce
on Mar 12, 2010 at 11:51:20 am
Hi There,
I'm working on a project for a client in Austria. We're shooting hi def, 720 50p in order to make the footage pal-friendly. We're shooting here in the US with HMI lighting (Kobold 400 - GREAT unit). Now I understand that flicker is something to watch out for with HMIs, but my producer is concerned that if our video, shot with lights powered by 60hz power might result in some kind of artifact when viewed in 50hz pal-land. Obviously, we'll be monitoring with lcd field monitors (battery-powered mostly) and so I assume that if there are any issues we'll see it there.
Are we just thinking too much? Any advice will be greatly appreciated.
Moo
Bob Pierce
http://www.lightstreamassociates.com
Mac Pro 2.66 - 8GB memory -
Mac Book Pro 2.33 Duo -
FC Studio 2 - Kona Lhe
Adobe Production Suite CS4 -
Sony Multiformat 14" - Panasonic 42" Plasma -
Ikegami HLDV7 - PVW EX-1
John Cummings
Re: HMI Flicker in Pal Land
on Mar 14, 2010 at 3:15:16 am
I may be wrong, because I've never tried it at 50p, but I don't think you'll have a problem with HMIs...especially using an electronic ballast like the Kolbold. They cycle at a much higher rate than say a fluorescent at 60 Hz.
J.Cummings
Chicago
HDX-900/HDW-730S/DXC-D50
Thomas Kist
on Mar 14, 2010 at 9:34:22 pm
If you shoot 50 fps in the States you have to be very carefull with fluorescents in the frame.
they will slowly flicker if the shutter speed is 1/50.
try using 1/60, but look out with mixing different light sources. tungsten, fluorescents and HMI because they make it hard to see the flicker.
Thomas Kist
Freelance D.o.P
Amsterdam,The Netherlands
PDW-700,Letus ultimate,FCP 6
http://www.thomaskist.com
