Flaming Toaster
COW Forums : Cinematography
Mark D'Agostino
Flaming Toaster
on Jan 7, 2010 at 9:17:23 pm
This should be fun...I need a shot of a toaster sparking and possibly flaming as if it short circuited. The sparks can come from the cord or from inside the toaster. I need the whole effect to last about 2-3 seconds. Before resorting to computer generated fx I'd like to start by trying to get this practically. Any suggestion that will allow me to keep my eyebrows?
Mark D'Agostino
http://www.synergeticproductions.com
Mark Suszko
Re: Flaming Toaster
on Jan 7, 2010 at 10:31:44 pm
Magicians have a special, relatively safe to use pyro powder that seems to throw sparks from your fingertips. You can order it thru magician's supply companies that cater to the trade.
Theatrical supply companies also offer pre-made squibs that will flame, smoke, or spark. You can make your own from some model rocket parts and igniters, tripping a custom powder mix, or simple flash paper wads. But this is easy to screw up if you're not an expert.
If you can foley the audio later, (because it will be noisy) another way to do this would be to rig a small DC electric motor inside the toaster, spinning an abrasive metal disk against a soft metal bar that will throw a fountain of sparks. A simple toggle switch controls when it works, you could power it with DC thru the old AC cord, or via radio control, the whole thing could be made from a surplus RC car with battery pack, speed controller, motor, frame, and wheel parts. Just change the tire to an abrasive wheel like from a Dremel moto-tool. This would be low voltage, with no chance of electrocuting anyone, but depending on the speed of the spinning disk and the type of metal, say, a "comb" of cheap music wire segments brushing that abrasive wheel, you could throw very large fountains of sparks this way, with maybe just a *little smoke.
But after suggesting all of that, I have to say that doing it in post is easier than ever these days, using either a particle system like wondertouch, or stock footage from a source like Digital Juice's compositor's kit. They will look real because they ARE real.
And nobody has to get hurt. My own choice would be a combo of sparks done in post and a little squib of simple flash paper done as a practical.
Ryan Mast
Re: Flaming Toaster
on Jan 8, 2010 at 5:39:50 pm
I agree with Mark -- post effect is easier and safer. Check with your insurance company before setting anything on fire.
However, some practical light from the toaster will help the post effect look convincing. You could use a strobe off-camera, or rig up some LED lights controlled by buttons that you can flicker.
Meteor Tower Films
Video creations for music, art, & theater.
http://meteortower.com/
John Fishback
Re: Flaming Toaster
on Jan 9, 2010 at 9:46:11 pm
My vote is for post FX. But layer the fx. Not only flame, but smoke and ejected particles. There are terrific tutorials at Video Copilot.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Mark D'Agostino
Re: Flaming Toaster
on Jan 12, 2010 at 4:25:31 pm
Thanks for the advice all. We'll be going the post effects route with the kind help from the advice you've posted. Doing it for real while possible, given my lack of experience with this makes it not the wisest choice, (but it would be pretty cool).
Mark D'Agostino
Mark Suszko
Re: Flaming Toaster
on Jan 12, 2010 at 7:24:56 pm
At least do this: hide a photo strobe in the toaster and trigger that. You can get remote-controlled ones, or wire one up. When the flash goes off from it, that will add a lot of nice on-set reactive lighting that will be motivated, and the talent has something physical to react to. Add the post effects to that on-set strobe flash, you will look great.
Mark D'Agostino
Re: Flaming Toaster
on Jan 12, 2010 at 8:02:20 pm
Thanks Mark.. I was also planning to stuff the toaster with treated paper an light that to get flame and black smoke and augment that with fx. There is no talent in the shot, just a couple seconds of the toaster doing its thing. I agree that the strobe will add a nice bit of interactive light.
Mark D'Agostino
James Dow
Re: Flaming Toaster
on Jan 25, 2010 at 10:10:33 pm
Is the Flaming Toaster a NewTek product?
JPD
