Infos upon the Panasonic Hvx201 and Hpx171
COW Forums : Cinematography
Daniele Massa
on May 14, 2009 at 8:42:35 am
Hi guys,
i am an indipendent filmmaker low budget and need to upgrade from sd to Hd.
I was interested in buying panasonic 201 but though there was no (at least little) difference between the two models.
Can anyone help me out to find out which are the real difference?
Ps. I also read that the only format 201 use for MiniDv cassettes is DVcam at 564i which is
pretty useless IMHO.
Cheers.
David Jones
Re: Infos upon the Panasonic Hvx201 and Hpx171
on May 19, 2009 at 10:36:21 pm
The biggest difference is that the 171 only shoots to P2 cards. It also has a wider-angle lens (28mm compaired to 30mm with the 201).
Dan Parsons
on Jun 17, 2009 at 11:44:23 pm
The HPX171 also has an HD/SD-SDI output terminal.
http://www.signaturelight.com
