Lipstick Cam with Wide-angle Lens Suggestions
COW Forums : Cinematography
John Fishback
on Apr 28, 2009 at 8:36:35 pm
I'm budgeting for an industrial where I need a 2-shot of a passenger and driver in the front seats of a car. The camera can be mounted off to the passenger's side and needs to be inside the car if at all possible. It should have a 16:9 aspect ratio and be standard def as the final will be a web video. Any ideas or recommendations?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Mark Suszko
Re: Lipstick Cam with Wide-angle Lens Suggestions
on Apr 29, 2009 at 12:46:02 am
Sony has a brand new one, just came out in the past month or two I think, should fit your bill, it is HD but you can use that to give you room to add re-framing and pans and zooms in post as you downconvert to the SD final, this HD down to SD, IMO, for this kind of job is ideal.
The review I read on it was glowing. We have an older Sony LS-1 that matched our betacams pretty closely, considering. It was and is a tremendously productive little camera for car work. In the time it took us to rig a full-blown hood mount for a conventional camera, the lipstick was able to get me five different POV shots using just a pad of foam rubber and some gaffer tape, from angles inside and outside the car that the bigger camera could never deliver. We got a variety of screw-on primes for it, a fisheye and a less distorting wide-angle, from a security camera company like Supercircuits ior similar.
John Fishback
on Apr 29, 2009 at 7:37:13 pm
Thanks, Mark
John
