Tripod problem (fluid head)
COW Forums : Cinematography
Greg Winkler
on Mar 16, 2009 at 6:49:06 am
We're using a Manfrotto 3274 fluid head, and no matter what we dial on the tension it is still super tight. We made sure it wasn't the locks, and the tension knob is pulled out when it is turned too (we thought that was the problem at first). Before I take this somewhere to be looked at, do you guys have any ideas as to why this might be happening? The tripod was purchased used.
Mark Suszko
Re: Tripod problem (fluid head)
on Mar 16, 2009 at 1:36:23 pm
Perhaps the fluid is missing, or under pressure?
Mark Suszko
on Mar 16, 2009 at 3:07:37 pm
I know that answer sounded weird, however, I did once come across a fluid head where the gel inside had solidified or emulsified or something, it was nasty. I have also heard of fluid heads developing leaks after long flights in unpressurized cargo holds.
Greg Winkler
on Mar 17, 2009 at 9:45:39 pm
So am I totally screwed then? How would I go about getting it repaired if that's the case?
James Dow
on Mar 25, 2009 at 3:19:12 pm
I've had similar problems with a Bogen 3066, which is made by Manfrotto. My fluid head had tilt issues. Anyway, I sent it off to Bogen repairs. Speedy service and reasonably priced. Their e-mail is: service@bogenimaging.com
JPD
