Projecting Super Eight on wall
COW Forums : Cinematography
Richard Chenoweth
on Sep 15, 2008 at 11:20:45 pm
Hey everybody,
I am projecting old Super-Eight, Eight, and Sixteen reels onto a wall and video-taping... it works
fairly well...
The projector is a GAF 1388. The video cam is a Canon Vixia HV30.
The projection surface is a bright white sheet of 13 X 19 heavyweight matte print paper.
I have adjusted and tweaked all surfaces and normals to eliminate "perspective".
The phenomenon I am getting is that the super-sensitive Canon is registering the flutter of the three-bladed GAF shutter wheel and creating a "fan-like" visual effect of dark-light fluttering. You can't really see it on the pure projected movie on the wall, but the super-sensitive Canon registers this flutter and totally exaggerates it so that it's pretty distracting.
Anyone have a work-around on this effect?
Many thanks!!
Richard
Jason Jenkins
Re: Projecting Super Eight on wall
on Sep 16, 2008 at 4:30:52 am
Have you tried adjusting the shutter speed on the HV30?
Richard Chenoweth
on Sep 16, 2008 at 1:02:22 pm
Jason, et al,
Thank you for responding. Yes, I was able to make the speed on the Canon "TV 60" and it
reduced the flutter appearance dramatically... Thanks!
I think the key is that the speed of Projector (not adjustable on mine) should evenly divide
into the speed of the Canon, so they are somewhat in sync... I think...
I found this interesting site on how-to procedure for this:
http://www.dvdhomevideoeditor.com/ARTICLES/TUTORIAL_howto_trans_8mmfilm.htm
Best regards,
Richard
Steven Bradford
on Sep 19, 2008 at 7:11:27 am
It's really worth it to get a Variable speed projector. They're around. I paid about $75 for mine off ebay about 8 years ago. Of course a five bladed projector is even better, but you can get decent results with a variable speed that you can trim to just the right speed to go into the sixty fields a second.
I also had much better luck projecting onto a matte GRAY surface (not textured) then onto a white surface. It helps control the contrast build, making it easier to control over exposure and clipping in the white areas.
Steven Bradford
Http://www.seanet.com/~bradford/
Richard Chenoweth
on Sep 19, 2008 at 3:15:37 pm
Great tips Steve... Thank you!!
Richard
