is 5600 kelvin enough for a Z1?
COW Forums : Cinematography
Antonio Atzei
on Sep 3, 2008 at 9:49:25 pm
Hi COWS!
I just had a meeting with the official photographer of the event I'll be shooting (fashion show party/catwalk) and he mentioned the light as an issue on the all evening. We may not have the minumum ideal 5600 kelvin ideal to show true or acceptable colors, so I was told. Where do I stand with the Z1 with at least 50 fps?
ciao
Txs in advance
AA
BABALOTTI PRODUCTIONS
SYDNEY
POWER MAC G5 QUAD SYSTEM
4.5GB RAM
1 TB OF MEMORY.
FCS 2
AJA KONA LHe
Todd Terry
Re: is 5600 kelvin enough for a Z1?
on Sep 3, 2008 at 10:28:52 pm
Hi Antonio...
That's just a little confusing, you might check with the photographer or whomever is actually in charge of the lighting design.
Degrees in Kelvin would be a measure of the color temperature of the light, not the amount of intensity or brightness (which would be expressed in some other form, such as lumens or footcandles).
Intensity/brightness and color temp are independent, one doesn't really have that much to do with the other.
5600K would indicate use of "daylight" instruments (HMI, fluorescents, or perhaps LEDs). I would think it would be highly unusual to find a fashion show (or any theatrical production) lit with daylight-balanced lighting. Tungsten-balanced lighting (more in the 3200Kish neighborhood) would probably be much more the norm. In addition, for something like a fashion show I can envision a wide range of color gels that might be on the instruments.
But as I said, the Kelvin specification only tells you the color of the light... which your Z1 can compensate for and yield properly color-balanced images regardless of the color temp. What you really need to know is if you have sufficient lighting output from the instruments, not color temp.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Antonio Atzei
on Sep 3, 2008 at 11:55:40 pm
Todd
Thank you for your very clear explanation. Well... no mather the photographer says I'll have to find out by myself when I switch on the camera.
Rds.
AA
SYDNEY
4.5GB RAM
1 TB OF MEMORY.
FCS 2
AJA KONA LHe
