jib/crane inexpensive????/
COW Forums : Cinematography
hdfilmmaker
on Sep 11, 2007 at 8:24:45 pm
What jib/crane does anyone recommend for under $600? It will have a Canon XL H1. and something like the Kesslercranes.
Is that the color red you want to use?
P. J. in Hollywood
Re: jib/crane inexpensive????/
on Oct 25, 2007 at 5:56:07 am
Unless you're going to use a jib often, it may be better to rent so you can find out what you like. You may also wish to consider a monitor so that you can see your image when your camera is 6 feet up.
