Camera Cranes
COW Forums : Cinematography
Hodge999
Camera Cranes
on Jan 17, 2006 at 9:10:07 pm
Could anyone recommend a Crane / Jib Arm package that would support a full sized D-30 Betacam Camera. I contacted Promax and they told me my camera was too heavy for theirs (Cobra Crane II). I've googled some others but it would be nice to get some thoughts on what works from the industry. Much Thanks!
Hodge
David Jones
Re: Camera Cranes
on Jan 17, 2006 at 10:32:42 pm
What type of budget?
Steve Wargo
Re: Camera Cranes
on Jan 17, 2006 at 11:41:54 pm
http://www.ezfx.com
We've had ours for 6 years and it rent it out daily. No problems.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Hodge999
Re: Camera Cranes
on Jan 18, 2006 at 4:09:01 am
That jib arm at ezfx looks pretty good. They have some nice testimonial video up there as well. It seems well constructed and at a reasonable price. Thanks for the info again Steve... as you've given me some good advice in the past!
PS. Hey Dave (CSIF), drop me a line. I read an old post saying that you made some track out of pvc pipe.
Mitch Gross
Re: Camera Cranes
on Jan 18, 2006 at 4:47:51 am
I have a Porta-Jib that I prefer to the EZ/FX jib. Personal taste thing, but I find it to be smoother and more versatile.
Mitch
Frank Otto
Re: Camera Cranes
on Jan 18, 2006 at 4:26:14 pm
If you have the budget, the Porta-Jib is (IMHO) the best small jib on the market. All machined and very smooth to operate.
Having said that, we own a EZ-FX jib. It's less expensive, but moves well. My only fault with it is the nylon bushings instead of bearings on the vertical travel points - and it does require tightening of the bolts on the vertical travel points occasionally. Set up is faster than the Porta-Jib, but not by much.
But for the price it may well be the best bet out there, especially for medium weight cameras (we use a Panasonic 575 w/DVCPRO 50 back - 18 lbs).
Cheers,
Frank Otto
Mitch Gross
Re: Camera Cranes
on Jan 18, 2006 at 8:29:32 pm
I should also point out that a friend of mine has an EZ/FX jib and has a devil of a time transporting it. It apparently only had some soft bags available and he couldn't find a hardcase to fit it. Frank, what do you use?
For my Porta-Jib, I could have purchased a hard case from the manufacturer, but instead found that I could fit the whole unit in the largest Storm Case (designed to hold a couple of rifles) and have room on the end for 60 ibs. of counterweights. The whole thing weighs about 175 ibs., but when flying I leave the weights behind and pick up something locally. And the case does have wheels on one end so it rolls easily, plus it will store standing up with no added support (I call it the monolith).
Mitch
Frank Otto
Re: Camera Cranes
on Jan 18, 2006 at 10:36:27 pm
Mitch:
Our jib never leaves the property...although that property is about 300 acres worth of the Las Vegas Strip ( Flamingo, Paris, Ballys, Caesars Palace, Harrah's).
It hangs nicely on a hotel Bell Cart and rides with an Arri light kit, the weights, c-stands, AC, tripods and heads, 14" monitor and WFM and misc grip stuff.We just roll (and it rolls very well) from site to site via the several miles of concrete connecting the resorts.
Your "monolith" sounds like the case we had made for our rig at Pacific Telephone - 3'x3'x6' - stand it on end and wheel the E.N.G (brand name) crash cart fully loaded into it and ship. We called our "the Coffin" which made for interesting comments picking up at air freight.
Cheers,
Frank Otto
Mitch Gross
Re: Camera Cranes
on Jan 19, 2006 at 6:45:12 pm
My monolith case is about 20"x8"x50". Pretty thin & fairly mobile on the built-in wheels. I used to have a video village built into a case that sounds similar to your beast, about 4'x2'x2'. Roll 'er onto set and pull off the top and I was ready for business, but I was always being banned from going anywhere near location because it was deemed too large for practical spaces in NYC, so it became client monitor.
Mitch
Mitch Gross
Re: Camera Cranes
on Jan 19, 2006 at 6:59:27 pm
A couple people have asked me about my "monolith" Storm Case. It is the iM3300 model, shown here:
http://www.cases4less.com/detail_storm_3300.html
It (just barely) fits my Porta-Jib with 60 ibs. of counterweights. It could probably fit some other small jibs like a Cinekinetic, Trovatto (does he still make 'em?), or Seven Jib. I don't think it would fit an EZ/FX jib, but perhaps it breaks down more than I know. You might be able to pack one in some tripod tubes, but that can get expensive if you need a few and the gear needs to be padded inside or it won't last very long.
Mitch
Steve Wargo
Re: Camera Cranes
on Jan 20, 2006 at 9:04:16 pm
The mini EZFX jib will fit in a case but the normal arm is 4' long and a little bit.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Dan Brockett
Re: Camera Cranes
on Jan 28, 2006 at 10:34:30 pm
Hi guys:
I too have been researching these smaller jib arms and have come down to buying either the EZFX or the PortaJib. The EZFX seems to be a little less expensive and not built quite as well as the PortaJib. I have rented a PortaJib and loved it, I have not had a chance to use an EZFX setup yet.
The PortaJib with everything I need (scissor attachment to the front, extension, monitor brackets, center post to mount and pan a tripod head) is about $4,500.00 total. The hard case for the PortaJib is almost $600.00 though.
Will report back if I buy one and live with it through a few different shoots.
Best,
Dan
http://www.biglittlefilms.com
Steve Wargo
Re: Camera Cranes
on Jan 30, 2006 at 2:28:35 am
The EZFX is about $2K with the 6 foot extension (total 10 feet). How long is the porta jib for twice the money?
You can add the electronic head from Prompter People and have an entire package with power head and ten foot reach for the same money.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Fred Iannone
Re: Camera Cranes
on Feb 17, 2006 at 10:31:23 pm
If it's not overkill, and you have a bit of budget, would the Areocrane be overkill? It can handle that much weight and more. I put a Panaflex/Arricam with 4:1 zooms and 1000' mags. You'll need a decent grip to assemble it.
