Green Screen Advice- Best Camera
COW Forums : Cinematography
Michael Pierre
on Nov 30, 2005 at 2:50:22 am
Excluding HD. Which camera would work best with greenscreen work? I've heard that the IMX and XDCAM aren't great due to NOISE.
Sony PDW-530 1000 Lines Digital Power HAD EX [16x9] XDCAM
Sony MSW-900 1000 Lines Digital Power HAD EX [16x9] IMX
Sony DVW-700WS 850 Lines Digital HYPER HAD 1000 f-8 [16x9] Digital Betacam
Sony DVW-700 850 Lines Digital HYPER HAD 1000 f-8, Digital Betacam
Sony BVW-D600 850 Lines Digital HYPER HAD 1000 f-8, BetaSP
Sony BVW-D600WS 850 Lines Digital HYPER HAD 1000 f-8, BetaSP
Panasonic AJ-SDX900P DVCPro50 24p/30i DVCPRO50
David Jones
Re: Green Screen Advice- Best Camera
on Nov 30, 2005 at 2:11:50 pm
Are you going to be in a studio environment where you can use a separate VTR or uncompressed NL workstation to record, or do you require a camera/recorder for field recording?
Michael Pierre
on Nov 30, 2005 at 3:42:00 pm
I won't have access to a deck. I'll be in the field.
Michael
David Jones
on Nov 30, 2005 at 11:17:25 pm
What format VTRs do you have available to play back your tape on, would be a consideration before selecting a camera.
Also what budget do you have including lens?
Also, how are you going to light your green screen in the field to give you a good key?
Paul Thurston
on Dec 9, 2005 at 6:27:29 pm
Hi Michael,
If you can, usa a Digital Betacam camcorder setup to record in 10-bit 4:2:2. Use soft TUNGSTEN lighting for the Greenscreen and foreground image. If that is not possible, use soft Daylight and make sure forground and background light levels are similar and that no shadow is seen on the greenscreen.
-Paul Thurston
shooter
on Dec 29, 2005 at 7:26:17 pm
Digibeta or the SDX900
