adapter baseplate
COW Forums : Cinematography
Richard Blakeslee
adapter baseplate
on Nov 12, 2005 at 7:51:18 pm
I'm looking for a baseplate that has a 3/8 inch mounting hole (to go on my old Miller tripod head) and a 1/4 inch mounting screw on top so I can mount my MiniDV camera. Is there such a thing?
Richard
Mitch Gross
Re: adapter baseplate
on Nov 13, 2005 at 7:07:54 am
A simple hole plate should do the trick. Any machinist could make you one. Try Willy's Widgets in Arizona if you can't find it anywhere else. The hole for the 3/8" screw from the tripod should be threaded but the 1/4" hole in the plate should not be.
Mitch
