Interesting depth of field device
COW Forums : Cinematography
Bob Cole
on Jun 21, 2005 at 5:38:44 pm
Just happened on an article about depth of field, how the smaller CCD's create excessive DOF, and how to build a device which addresses the issue.
http://www.mediachance.com/dvdlab/dof/index.htm
-- Bob
Bob
Re: Interesting depth of field device
by
on Jun 22, 2005 at 2:08:03 pm
WOW! Now that was a fantastic display of ingenuity! Looks like the results were quite impressive.
mitch gross
on Jun 30, 2005 at 3:16:44 am
This has been around for a little while now. I believe the website creator eveolved the item into an actual product. If it's not him then it is a design of a very similar nature. It's called the Micro35 and sells for an astoundingly low $500. Properly machined and built to tight tollerances using a real groundglass, not fiberboard and a plastic CD blank, so it has far better performance than the DIY version. I'm probably going to pick one up soon having seen it in person and impressed.
Mitch
