step up/down rings
COW Forums : Cinematography
Jim Mulleder
step up/down rings
on May 3, 2005 at 4:31:24 pm
Hello cowsters,
I have a 77mm lens on a Betacam and some 72mm filters, if I purchase a step down ring to convert will I
see some vignetting from the conversion?
Cheers
jim
Jim Mulleder
Techical Producer
http://www.telestudios.ubc.ca
Todd McMullen
Re: step up/down rings
on May 5, 2005 at 12:44:48 pm
Possibly on the wide side of the lens.Keep filters close to front element and you should be ok. Unfortunately, only way to know is to test it out.
Todd McMullen
Flip Flop Films
Austin
Jim Mulleder
on May 5, 2005 at 2:38:32 pm
Todd,
Thank you for your insight. I am looking to test but finding the step down ring in the area has been a problem.
Cheers
Jim
Jim Mulleder
Techical Producer
