What light is this?
COW Forums : Lighting Design
Trey Eckles
What light is this?
on Jan 17, 2015 at 9:32:16 pm
Anyone know what type of light this is? The flat window shaped rectangular one. I think the photographer may have rigged that himself. If so, anyone have an idea how I could set something like thing up?
https://scontent-a-ord.xx.fbcdn.net/hphotos-xpa1/t31.0-8/10687854_101530828...
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xfa1/v/t1.0-9/s720x720/26...
john sharaf
Re: What light is this?
on Jan 17, 2015 at 9:47:22 pm
Hi Trey,
Likely a Rosco Lite Pad mounted in the frame. Here's a link:
http://www.rosco.com/litepad/litepadHO.cfm?menuReturn=litepad
Also there are many types of LED strips which you can customize into different uses from Lite Gear:
http://www.litegear.com/
Has a similar look and effect of Kino "Bar Fly" which is fluorescent vs. LED, but some of the other lights in the shot clearly are Kino Flo Products, I'm not exactly sure which one you're asking about, but maybe these links will help you out.
Good luck,
JS
