Barndoor Size
COW Forums : Lighting Design
Nigel Thompson
Barndoor Size
on Nov 8, 2014 at 8:09:52 pm
Hi Guys :
i bought a pair of used DN LABS 2.5K HMI's they work great but came without barndoors. Will these work
http://www.bhphotovideo.com/c/product/575661-REG/Arri_552210_Four_Leaf_Barn...
BH did not put the actual diameter on the item but the DN 2.5 has an 8" Par lens front ..
Thanks for the advice
Nigel
High End, Production & Post Production
in the Caribbean
http://www.bistt.com
Dennis Size
Re: Barndoor Size
on Nov 9, 2014 at 5:35:29 am
The chances are extremely good those ARRI barndoors will not work.
You need to measure your accessory frame holder distance and find another fixture that is an exact match. You should never assume the accessory holder clips for the barn doors and color frames are the same because the lens diameter of a fixture is the same.
DS
