Making fluorecent lights flicker
COW Forums : Lighting Design
John Shand
on Dec 2, 2012 at 4:26:46 pm
Hi All, how could you make fluorecent lights Flickr on purpose. We want to create a sense of danger. Turning them off and on doesn't make them flicker quick enough. Any info would be really appreciated.
john sharaf
Re: Making fluorecent lights flicker
on Dec 2, 2012 at 4:45:49 pm
John,
Although the flicker might be too rhythmic for your taste, you could adjust the shutter to introduce flicker; perhaps if your camera has the capability to dynamically adjust the shutter speed while rolling you could make a creative effect.
JS
John Shand
on Dec 2, 2012 at 11:45:14 pm
Thanks for you reply John, yes it would have to be more realistic, like when a flo light is faulty.
Mark Suszko
on Dec 4, 2012 at 8:32:56 pm
I keep a set of nearly-dead tubes for this, that's REALISM!.
You can also derange a perfectly good flo light by introducing a magnet along the length of the tube. An electromagnet with variable power gives you more control over the effect. This is a case of trial and error experimentation.
John Shand
on Dec 6, 2012 at 1:25:16 pm
Perfect! The electro magnet is the one. But from now often I'm going to start collecting old flo lights. I wonder what offices do with them, hopefully they don't get thrown away.
Mark Suszko
on Dec 6, 2012 at 10:26:16 pm
Sometimes its the ballast and not the tube that dies, and there are pro setups for monkeying with the ballast.
Dennis Size
on Dec 7, 2012 at 6:35:54 am
You could also introduce a dimmer into the mix. Dimming down non-dimmable fluorscent tubes will often cause them to flicker erratically.
Another alternative is to use the new LED source "fluroescent" fixture tubes. They might offer more of a controllable effect.
DS
