OK to use 2 different wattage CFL bulbs in multi-bank softbox light?
COW Forums : Lighting Design
Harry Pallenberg
on Aug 18, 2012 at 8:21:19 pm
Is there any reason to NOT mix 2 different wattage CFL bulbs in a multi socketed head - you know the cheap softbox kind that takes 6 bulbs and has 2 power switches so you can turn on 1 bank at a time? My thinking is that rather than have 2 options (half & full), I can have 3 options (3x30 watt, 3x85 watt and both).
The ballast is in the bulb so should not be an issue - right? Especially if bulbs are from same manufacture and have same temp & CRI?
Am I missing something?
Sample of multi socket head.. but there are dozens of them out there:
http://www.briteklight.com/product/Linco-PE9030-3350.html'>http://briteklight.com-http://www.briteklight.com/product/Linco-PE9030-3350.html
Harry
Forum Cowmunity Leader: Indie & Doc
Forum Cowmunity Leader: HDV
2.93Core i7 ** 4GB ** 10.6.7 (Office / Photoshop/ FCP 7)
Where They Raced
http://www.wheretheyraced.com
http://www.harrypallenberg.com
Bill Davis
Re: OK to use 2 different wattage CFL bulbs in multi-bank softbox light?
on Aug 18, 2012 at 9:49:49 pm
Can't really think why there would be a problem.
Just because I'm a bit obsessive about lighting, I'd rig it that way and do a simple test.
Whatever camera you're using, lock it to all manual settings. Then shoot a test and switch the light through all it's settings.
Watch the result.
If you don't get significant shifts in anything other than brightness, you're good to go.
"Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions."-Justice O'Connor
Harry Pallenberg
on Aug 20, 2012 at 3:28:28 pm
Seems like a missed advertising opportunity for just about EVERY single multi-bank seller out there. "Not 1, not 2, but 3 possible settings"....
Harry
Where They Raced
Bill Davis
on Aug 20, 2012 at 6:38:37 pm
[Harry Pallenberg] "Seems like a missed advertising opportunity for just about EVERY single multi-bank seller out there. "Not 1, not 2, but 3 possible settings"...."
Well, kinda.
The problem is that the industry years ago licked the problem of dimming fluorescent sources. So 3 possible settings is all well and good, but not nearly as useful as an infinitely variable dimmer.
Still, nothing wrong with these at all. Just understand that at some point these "budget" solutions give way to spending money for the kind of gear that gives you more performance - obviously at a higher price.
FWIW.
