Buying fluorescent lights for green screen shoots.
COW Forums : Lighting Design
Larry Watts
on Jan 4, 2012 at 6:06:23 pm
I've done a half dozen green screen shoots with tungsten lights. I've also keyed those in editing and understand the issues.
I want to total fluorescent with my new portable 9' x 18' green screen because of heat and power draw.
I will be shooting an on camera host with a single camera, although I will be using either a Canon 5D MKII or a Canon XF305.
I already own photoflex's DSLR kit which has a 500 watt equiv. fluorsecent light with softbox.
I'm concerned that if I light the talent with two 500 wat equiv fluorsecent light with softboxes there may not be enough light for the Canon XF305. with using the gain.
How can I tell if I have enough light without testing, which I cannot do at this time.
Any lower cost suggestions on lighting the screen with fluorescents?
John Fishback
Re: Buying fluorescent lights for green screen shoots.
on Jan 5, 2012 at 8:34:13 pm
I'm not sure I understand your question. Are you trying to light both the talent and greenscreen with the same two instruments? Do you have a light meter?
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
© 2018 All Rights Reserved
