The difference between the voltage of lights
COW Forums : Lighting Design
Zach Rohrer
on Jul 19, 2011 at 7:12:19 am
This is going to be a noob worthy question.
What is the difference between a 120V and a 220V tungsten light? Does it have any effect on the temperature or the brightness of the light? Apologies for my ignorance! lol
John Fishback
Re: The difference between the voltage of lights
on Jul 31, 2011 at 10:05:09 pm
The two bulbs are not interchangeable. One is designed to be used with 120v service which is common in the US. The other is designed for 220v service as is found in Europe. Plug the 120 into 220 service and watch the bulb go pop. Plug the 220 into 120v service and it will light, but be very dim. I've never tested this, but I'd guess if you compare the output of a 120v, 1000 watt bulb with a 220v, 1000 watt bulb they'd be similar.
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
© 2018 All Rights Reserved
