Redheads and Blondes - any lower wattage bulbs available?
COW Forums : Lighting Design
Harry Bromley-Davenport
on Oct 20, 2010 at 11:45:09 pm
I have 3 Ianabeam 800 watt Redheads and 3 2k Blondes. Does anyone know where I can obtain lower wattage bulbs for these lamps?
I don't want to have the hassle of under-running them and the consequent color temperature correction.
Many thanks,
Harry.
Dan Brockett
Re: Redheads and Blondes - any lower wattage bulbs available?
on Oct 21, 2010 at 6:25:05 pm
Not sure which country you are in Harry, but according to the Ianiro website, you can purchase all kinds of smaller wattage bulbs for the 800 but not for the 2k version.
The lamp socket is known as R7s 80mm for the 800, R7s 93mm for the 1k version and R7s 140mm for the 2k version. The specs for the smaller wattage lamps are here http://www.ianiro.com/redhead_fibre_ita-asp.php scroll down to the lamp chart.
Any reliable vendor that sells bulbs will have them, http://www.bulbtronics.com , probably http://www.filmtools.com , if you are here in the U.S. etc. If you are in Australia or the UK, I am sure that there are equivalent pro line retailers.
Dan Brockett
A Producer Who Is Also A DP? Yep, that's Me.
http://www.danbrockett.com
on Oct 21, 2010 at 10:40:10 pm
Thank you very much for all the useful information. And I am here in the US.
Best wishes and thanks again.
Harry.
