custom gobos - sources
COW Forums : Lighting Design
Bob Cole
on Oct 8, 2010 at 8:35:40 pm
I need some custom gobos (client logos) for my Source 4 Jr Zoom. I need a good one made of metal that won't burn up right away, and which is made by somebody intelligent enough not to try to cut too fine a pattern (as those seem to have a tendency to burn up). There are a number of suppliers on the first Google search page, so I wanted to ask the experienced hands here for a recommendation for a gobo maker.
Thank you.
Bob C
Scott Henderson
Re: custom gobos - sources
on Oct 9, 2010 at 3:56:18 pm
Hey Bob, we have been buying gobos from Kinetic Artistry in Tacoma Park
http://www.kineticartistry.com/
Michael Easparam
on Oct 9, 2010 at 4:06:03 pm
The largest that I know of is Rosco. That's who we use, and we've never had any issues. Apollo is also good, I have used some made by them but never ordered any.
To be honest with you, the Source 4 Jr is not a great choice for metal gobos. It requires a smaller gobo size (43 vs 58mm) than a full size Source 4, but attempts to shove the same amount of light through it. The Jr is pretty inefficient, being considerably less efficient than it's big brother. With a 575w lamp in both - at 50 degrees is about 60%, at 25 degrees is only 50%. Many people buy the Jr because they don't need the extra lumens, but it's a better idea to buy the full size and lamp at 375w. However, the full size zoom is ridiculously large and I find the Jr zoom to be quite good compared to the regular Jr.
A metal gobo in size B (58mm) should last for at least two 4hr sessions without much deforming of the edges (assuming your lamp is centered properly). Beyond that, it's a matter of detail. I wouldn't say it's up to the manufacturer of the gobo to decide how thin lines of detail are or not. They are going to make the closest thing they can to the graphic you send them. However, we project gobos all the time that are extremely detailed and of course they burn up quite quickly. It's just the nature of the beast. If you don't need that kind of detail either tell them or modify the graphic appropriately yourself.
If you find that life span above too short, you really need to buy screened dichroic glass gobos instead. They are meant to last, you will likely damage the gobo from handling before anything else happens to it. Plus, they look better and you can introduce colors.
Bob Cole
on Oct 10, 2010 at 8:59:05 pm
Thanks Scott and Michael.
I'm fairly committed to using the Source 4 Jr. Zoom, for ease of packing. The idea of simplifying the logo, i.e. removing some of the finer filigree work, is a great one. I've noticed the same thing, that the fine metal burns much more rapidly. My favorite abstract patterns are two that I cut myself, out of aluminum cake pans. Very durable too!
Have you successfully used glass gobos in a Source 4 Jr. Zoom?
bob
Dennis Size
on Oct 10, 2010 at 9:08:44 pm
Frankly, if the budget is available, glass is always the way to go. It's what I recommend to all our clients, and ultimately end up using when they're not happy with the metal templates (which always require "spoking" to keep the negative space from falling out).
They work fine in Juniors ....just make sure if you go with glass you order the correct size, and have the correct pattern holder.
Apollo does an excellent job with glass, as does Rosco
DS
Mark Suszko
on Oct 11, 2010 at 10:15:31 pm
Our source four junior takes a Type "M" gobo, we had Rosco cut a metal gobo for a client logo.
These days any metal shop with a laser can also do this for you if you give them dimensions and a vector file.
Michael Easparam
on Oct 12, 2010 at 1:01:41 am
I've never used a glass gobo in a S4 Jr, but I don't see any reason why it would not work just fine. You will need to order a special holder for glass gobos since they are 1-2mm thick, instead of sheet metal.
