Outsourcing MMA Event Lighting
COW Forums : Lighting Design
James Carson
on Apr 20, 2010 at 6:58:23 pm
I'm planning to hold an MMA event later this year and I want to have professional lighting for the event. It will be held in a small venue that seats about 1,500 people. The lighting rig won't be able to be hung. What should I expect to pay for lighting this event? Any things I should keep in mind when looking for someone to light the event? There needs to be plenty of light on the ring and crowd since this may air on local tv at some point.
Dennis Size
Re: Outsourcing MMA Event Lighting
on Apr 21, 2010 at 2:37:42 am
MMA ????
Mark Suszko
on Apr 21, 2010 at 1:27:49 pm
Mixed martial Arts. Like a boxing ring.
John Fishback
on Apr 22, 2010 at 2:00:20 pm
Google for a staging company in your area and ask them.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Dennis Size
on Apr 23, 2010 at 11:46:34 pm
$20,000 for the "do it on the cheap" low end, and $40,000.00 to do it right.
DS
Bob King
on Jun 2, 2010 at 10:44:39 pm
You could, depending on the venue, ground support a truss box (40'x40') off Genies. This would get a 'flown' rig and also give you somewhere to hang PA. You can light the ring with PARs. I think the budget that's already posted is about right.
If you look at a PPV fight done in Vegas, they won't use a much more complicated rig, just a larger one with some movers and leko specials.
Hope this helps.
-bk
