Mixing different grip equipment?
COW Forums : Lighting Design
kat hayes
on Oct 9, 2008 at 6:31:16 pm
Will different c-stand components, such as a Matthews Quaker clamp work with an Avenger c-stand?
Thanks.
john sharaf
Re: Mixing different grip equipment?
on Oct 9, 2008 at 6:34:27 pm
Kat,
The simple answer is yes, as there are standard sizes for baby mounts on light and stands. Be sure and mark all your gear with the same color paint or tape labels though, so when you are mixing up with other crews or rental gear you'll be certain to get your stuff back at the end of the day.
JS
kat hayes
on Oct 9, 2008 at 7:13:35 pm
kat hayes
on Oct 10, 2008 at 3:33:14 am
Are there any issues with creating adhesive labels from a Brother label maker and affixing labels to any of the following:
- outer metal frame around a scrim
- an Arri light fixture
- the back of a Kino fixture
Will these melt or worse, potentially catch fire?
Michael Palmer
on Oct 10, 2008 at 3:49:54 am
Kat
It is a very good idea to label your equipment as most bestboys in the business do when checking in the rental gear. Sub-rentals may get a different color label so they can be flagged to be returned first. As for lights I recommend you use the yoke or any suitable place that doesn't heat up. Kino's can be anywhere. Just remember to mark every piece of gear as long as you are doing it.
Good Luck
Michael Palmer
Ben Ferrer
on Oct 10, 2008 at 4:47:34 am
I recommend covering inkjet labels with a strip of transparent tape. This will protect the type from rubbing off.
-Ben
Ben Ferrer
- DP - SF Bay Area
