chroma key lighting
COW Forums : Lighting Design
jean-yves le moine
chroma key lighting
on Aug 20, 2008 at 10:36:12 am
hi all
i m searching diagram for lighting people on chroma key.
i m looking for simple ones to give examples to student
thanks a lot
jean-yves le moine
Michael Palmer
Re: chroma key lighting
on Aug 20, 2008 at 2:21:23 pm
You can light your subject in any look you desire, however a rim or back light can help you key out the back ground later. The biggest mistake you can make is to over light the green screen and have that light bouncing back onto your subject as this will make it very difficult to key, so separate the subject far enough away from the green screen and control the light level on the green screen to a stop below the subjects key light and you should be good.
Good Luck
Michael Palmer
