Lighting reflective black perspex?
COW Forums : Lighting Design
Simon Cox
on Jul 29, 2008 at 5:30:43 pm
I'm just about to start studio shoot where a presenter will be demonstrating everything from large fridge freezers to sat nav's.
It will be fully blacked out with high gloss black perspex floor tiles and a plinth made of the same material.
The idea is to see the presenter / item reflected in the floor but obviously not myself, kit and lamps. Clearly I have to light the presenter and item as well.
It's going to be like filming with mirrors I reckon and would appreciate any feedback from anyone who's found themselves in a similar situation.
I would assume that I'll have to drape myself and camera in black drape, however I'll also have an Autocue device attached to the camera, (970 digi shooting prog).
Regards,
Simon
Rick Wise
Re: Lighting reflective black perspex?
on Jul 29, 2008 at 7:09:30 pm
Indeed, that situation can be very tricky. The obvious thing to keep in mind -- which you no doubt know well -- is that the angle of incidence equals the angle of reflection. If the light is coming in at 45º it will bounce off at 45º in the opposite direction. When the reflective surface is flat, you can usually place lighting units so that the camera does not see the reflection of the unit. But when the surface is curved, the task can be enormous. Well-placed flags often save the day. Black wrap is also useful, Sometimes wrapping c-stands and light-stands with duvetine also helps remove unwanted gleams of reflection.
A slightly different and probably easier approach is to use very large soft lights. There are special rigs DPs use to light cars which are essentially huge soft boxes longer than the car itself, which is how they get those excellent highlights along the folds of sheet metal. Several 4x8 white foamcore sheets strategically placed end to end, illuminated with roughly equal intensity by floor lamps whose own reflection is blocked by duvetine or black foamcore can, with a lot of work, emulate such a look. Or else overhead space lights or "chicken coops" through a giant silk.
I suggest you make sure your client understands that all this takes time, time, time, and crew, plus grip and electric equipment, to do right.
Rick Wise
director of photography
Oakland, CA
http://www.RickWiseDP.com
email: Rick@RickWiseDP.com
Simon Cox
on Jul 29, 2008 at 10:18:49 pm
Many thanks, it's the direction I thought I should head in. Good news is we now have a rig day to experiment with and the BBC have left some space lights up that I can use. Hopefully by the end of tomorrow things will be in good shape.
