Lighting for stop motion animation
COW Forums : Lighting Design
jjordache
on Aug 14, 2006 at 3:14:19 am
I
john sharaf
Re: Lighting for stop motion animation
on Aug 14, 2006 at 3:18:22 am
Johnny,
Check out the Lowell Ego; it's great for tabletop and other small subjects like your puppet, especially if you want to create a daylight-type look. Here's the link:
http://www.lowelego.com/
JS
jjordache
on Aug 14, 2006 at 4:39:57 pm
Thanks, John! I found a local distributor and I
john sharaf
on Aug 14, 2006 at 5:54:20 pm
Johnny,
The Ego would be a good key light and depending on its placement will be either contrasty of flat, also use of fill card or even black "negative fill" card can control the contrast.
Choose a small fresnel like a 100watt Pepper for the backlight, or enen a 6" Kino Mini Flo.
JS
David Jones
on Aug 14, 2006 at 10:47:19 pm
Flashlights.
Dennis Size
on Aug 15, 2006 at 2:40:05 am
Every reputable lighting company out there has very small 100w sources. Check out what's available.
Whenever I do "tabletop" and model work I use Dedo Lights (which come with a variety of accessories), Mini-Kino Flos, or ARRI Pocket PAR fixtures with their fiber optic tube attachments. I've also used a fiber optic illuminator as a single source and run up to six tubes out as my lighting positions.
DS
