A good all around lighting setup
COW Forums : Lighting Design
RecTeach
on May 6, 2006 at 6:43:17 pm
I need to purchase a good general setup for a teaching program. Something that will work well in several situations. I have around $2000.00 or so to spend on this.
Frank Otto
Re: A good all around lighting setup
on May 10, 2006 at 2:42:11 am
If you are new to lighting or are from a discipline that may not be grounded in lighting, I'd recommend checking out B&H's on line catalogue just to get a idea of what goes into a kit. Check out eBay for used lighting gear - 2k goes a long way.
General set up is so...I don't know...general? Are you teaching E.N.G., high key, low key, noir, two point, three point, key-kick-slash? An Arri SoftIV kit will work well for many set ups, but then so will a Altman or even Lowell - for the budget you have.
So when you have an idea of what's available out there and mate that to what you're going to teach then check back in to this forum... if you have more questions, we'll be here to help.
Cheers,
Frank Otto
