Flo's in a softbox?
COW Forums : Lighting Design
rich rosen
Flo's in a softbox?
on Mar 17, 2006 at 12:59:13 pm
Wondering if it's redundant to put flo's in a softbox? Do flo's create the same wrap around light without a softbox? Thanks.
Leo Ticheli
Re: Flo's in a softbox?
on Mar 17, 2006 at 3:02:50 pm
Yes. And no.
First, consider the Softlight Law:
"The softness of the light is directly proportional to the relative size of the aperture of the light to the subject." The aperture of the light is the size, for example a 4' x 6', and has nothing to do with the lens aperture.
A Kino Flo has a larger aperture than a naked Fresnel or open-faced lamp, so it's softer at any given distance from the subject. That's the "yes" part of the answer.
On the other hand, the Kino Flo aperture is much smaller than the size of most softboxes; that's the "no" part of the answer.
So, here's the deal; Kino Flo fixtures with out diffusion to increase the size of the aperture are soft, but not as soft as a larger aperture softbox.
I would never put a Kino in a softbox, however; their silk is too dense, designed for hot, higher wattage lights. Just put so light diffusion over the Kino Flo doors and that will do the trick.
I like very light diffusion for many shots because it has a bit of hot spot, giving a nice soft look with more snap than a solid softbox.
Good shooting!
Leo
rich rosen
on Mar 17, 2006 at 3:31:39 pm
Are you talking a sheet of tough spun for diffusion?
