Where do I find Mylar?
COW Forums : Lighting Design
David Distinti
on May 16, 2005 at 2:20:41 pm
I need to block all natural light from coming in through our location's windows.
I understand sheets of mylar will do the trick. Where can I find it and what type of
mylar should I request.
Also,
If mylar is expensive, is there a cheeper alternative?
Dave
Leo Ticheli
Re: Where do I find Mylar?
on May 16, 2005 at 2:30:52 pm
A "cheeper" alternative would be a flock of baby chickens.
A cheaper alternative would be standard construction material black plastic.
Best regards,
Leo
Director/Cinematographer
Southeast USA
David Distinti
on May 16, 2005 at 2:44:23 pm
Thanks for the "cheep" tip. :)
- Dave
Bob Cole
on May 16, 2005 at 3:47:37 pm
This forum is going to the birds.
Dan Rahmel
on Jun 10, 2005 at 9:00:38 pm
You're trying to block all the light? It seems like you want sheets of Duvetyne (a solid non-reflected black cloth you can get at Film Tools). I guess I don't understand exactly what you're looking for.
For Mylar, take a look at TAP Plastics (http://www.tapplastics.com). I've ordered from them a couple of times and they were good. They have mylar rolls (mirrored and clear) you can order.
Mylar is usually fairly expensive and traditionally used for its mirror-like surface. If you don
