Relinking the entire project
Daniil Deych
on May 17, 2020 at 8:33:00 pm
Hey everyone,
My working HD drive started to fail on me, so I transferred all of the footage and the entire project (with the folder and bin structure being exactly the same) onto a different one.
However, now when I reopen the project on a new drive, none of my media is linked. I tried relinking, but came up empty.
It is an online edit, and I'm using the MC 2020.4.
I'm sure there was something that I should've done instead of just copying everything onto a new drive, but would you know if there is a way to fix it? Any help would be greatly appreciated.
Cheers,
D.
Eric Santiago
Re: Relinking the entire project
on May 18, 2020 at 1:11:55 am
Did you mean you created a new Avid MediaFiles folder on a different drive?
What does the folder structure look like from the root?
If you can, check the existing one in your previous Avid drives.
It should look like this:
DRIVE
Avid MediaFiles
MXF
1 (or whatever but it needs the mdb files in it to know that its a blessed folder).
Daniil Deych
on May 18, 2020 at 2:39:23 am
I didn't so much created, but simply selected everything on one drive and moved it, as is, to another blank one.
I basically hoped the only thing i'd have to do is to relink the files to a new drive from within the project, but clearly I was wrong.
Daniil
Pat Horridge
on May 18, 2020 at 7:22:05 am
The process isn't relining as that's intended for Avid media (which would have transfered across with less issues)
To link back AMA content.
Make a new bin or bins.
And link again from the source files into that bin or bins.
As you do the original clips and the sequence will come on line.
Hide those new bins away when done.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk
Daniil Deych
on May 20, 2020 at 4:28:47 am
That did it. Thank you!
D.
