Trying to remove the shaded area
Ted Corriero
on Dec 16, 2019 at 10:00:12 pm
Badly lit - client would like this on a pure white background. It's already been colored corrected and I'm using the Luma Key to get me this far - any suggestions?
Shane Ross
Re: Trying to remove the shaded area
on Dec 16, 2019 at 11:51:49 pm
Animatte over a white background.
Shane
Little Frog Post
Glenn Sakatch
on Dec 19, 2019 at 3:42:54 am
Build it into a nicer white background...don't worry about the interference with the purple
Then above that key the purple back in
Above that a loose animate around the head.
That purple shirt should key back in rather easily, so you can be pretty liberal to get the BG white.
Glenn
Ted Corriero
on Dec 21, 2019 at 6:01:19 am
Thank you
