Syncing timecode
Sean Lennon
Syncing timecode
on Dec 11, 2019 at 8:28:42 pm
Hi, is there a way to show timecode in my video and my audio bins view so that i can then drag the corresponding ones into a sync bin for syncing?
Cheers!
S
Sean Lewis
Re: Syncing timecode
on Dec 12, 2019 at 12:44:57 am
Hey Sean,
If I'm reading your post right, it's a simple answer. Yes - the columns you want are called "Start" and/or "End" - for start timecode, and end timecode.
Sean Lennon
on Dec 12, 2019 at 10:21:17 am
Yes thank you. And can I batch sync if all audio and corresponding video are in one bin?
Sean Lennon
on Dec 12, 2019 at 10:27:53 am
Also, can I sync to subclips I've made?
Sean Lewis
on Dec 12, 2019 at 9:56:38 pm
Hey,
Yep, if all audio and video master clips are in one bin, you can select all and 'autosync'.
I don't think you can sync to a subclip. It has to be master clips. If you need to join subclips with other subclips that's called a 'group'.
Michael Phillips
on Dec 12, 2019 at 11:02:39 pm
You can AutoSync subclips with other subclips or master clips.
Michael
Sean Lennon
on Dec 17, 2019 at 10:24:06 pm
Thank you
Sean Lennon
on Dec 17, 2019 at 10:50:43 pm
Hi Michael, is there a way of doing this using timecode, as the subclip changes the timecode start time, so if i drag subclips into a bin with its corresponding audio master clips will autosync work?
Cheers again
Sean
Sean Lennon
on Dec 17, 2019 at 10:24:31 pm
Thank you
Michael Phillips
on Dec 19, 2019 at 11:43:37 pm
Timecode is correctly maintained in the subclip as the correct offset to its master clip.
Michael
Sean Lennon
on Dec 20, 2019 at 12:04:28 am
So as I understand you Michael, autosync see's the subclip timecode as linked to master clip timecode and therefore will sync correctly to audio?
Michael Phillips
on Dec 20, 2019 at 2:26:23 am
I'm a bit unclear as to your overall question or goals, but when syncing Video to Audio with a common timecode, the resulting clip will be based on the sync timecode relationship between the two for the duration of the shortest clip of two clips being synced.
A video clip from 01:00:00:00 to 01:01:00:00 and an audio clip that is 00:59:00:00 to 01:02:00:00 will result in a clip that is 01:00:00:00 to 01:01:00:00. If the audio clip was subclipped in this example was 01:01:10:00 to 01:01:50:00, then the resulting sync clip will be 01:01:10:00 to 01:01:50:00. The same is true for video being subclipped. A resulting .sync subclip will never have filler (black) for either video or audio.
Michael
Sean Lennon
on Dec 20, 2019 at 9:13:19 am
Thanks, I'd created subclip's before syncing external sound to video. So I wanted to get to the bottom of how timecode operates between subclip's and audio. I get you know, the audio will sync and be truncated based on the subclip's timecode and vice versa.
