DPX only importing the first 99 frames
Ricky Milling
on Oct 4, 2019 at 8:30:10 pm
Hi all, im adding a lot of VFX shots (normal/alpha) for a film and most of them are coming in fine, however ive noticed that some are being cut off at the 99 frame mark rather than the full amount, in this case 108 frames.
I have no idea what is going on or why this is happening, any advice?
In resolve the full 108 frames are imported.
Im working iwth a 25fps project and the DPXs are also 25fps.
Currently working on 2018.12.2
Michael Phillips
Re: DPX only importing the first 99 frames
on Oct 5, 2019 at 2:51:13 am
What's the numbering format look like from the 99th and the 100th frame?
Michael
Glenn Sakatch
on Oct 5, 2019 at 3:44:04 pm
Yes you might want to run them through a batch numbering process to add some leading 0's so that all files have the same number of digits.
file_000099.dpx
file_000100.dpx
vs
file99.dpx
file100.dpx
Glenn
Ricky Milling
on Oct 6, 2019 at 6:18:27 pm
bch001_v06.098
bch001_v06.099
bch001_v06.100
bch001_v06.101
Will ask them to have a look at the files in this case.
